Results 1 to 15 of 18
Thread: Anybody ever epoxy coat their garage floor?
    Phoenix, AZ.
    6,719
    Not sure exactly what the stuff is called. Just wondering approximately how much a 2 car garage would cost to coat and what kind of prep work needs to be done first.
    My garage looks like crap. Sick of looking at it like that. Not to mention it seems like cleanup would be easier. I figure coating the floor and a fresh coat of bright white paint on the walls and ceiling would also boost the ambient light levels quite a bit so I can see what I'm doing a little better.
    Infinity Cycle Supply LLC.'s Avatar
    Infinity Cycle Supply LLC. is offline Formerly: rangerover,EASTCOATATVLLC Arm chair racerJust too addicted
    Nov 2005
    Avon Lake Ohio
    564
    Quote Originally Posted by Dammit!
    Probably a few hundred and they are wonderful. Just sprinkle the cleaner they give you on the floor hose out and let dry. Them apply it, cleanup is much better afterwards.
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    let me know the name of the paint suppliers near your home and I'll tell you product and prep...
    I always use a 2 component aliphatic urethane or a solvent based epoxy
    it withstands full water submersion and every chemical you can throw at it....
    slippery as hell when wet but I would still aviod throwing silica sand in it for an aggregate...reason being the sand can be crushed leaving a possible void in the membrane surface...
    theres a product that is called "shark tooth" that is titanuim oxide in make up that can be used as an aggregate but i would avoid using any at all, makes it easier to maintain...i.e.clean up
    ballpark for materials would be about 60.00 per 1 gallon kit, average 2 car garage would take 3 gallons for a good dry film thickness plus you would need a charcoal cartraige (sp.) breathing resperator for about 25.00 so you don't die while it's venting off or drying..you need about 20.00 for a gallon of proper solvent for clean up or whatever... and last but not least, about 10.00 for a throw away brush and rollers
    Phoenix, AZ.
    6,719
    How long does it take this stuff to dry? I'm wondering what I do with my trikes etc while I'm doing this. I was thinking move everything to one side of the garage and do one side at a time.
    Las Vegas, NV.
    2,504
    That's the way I did my 2 car garage, moved everything to one side, and painted them a few weeks apart. It looks great so far, and cleanup is a breeze. The floor has been coated now for about 6 months. I used Rust-oleum Epoxy Shield 2-part epoxy when I did my floor. I wasn't planning on sprinkling the little colored paint chips onto the wet floor, because I thought they would make it difficult to find the inadvertantly dropped small nuts, bolts, screws, etc., but it just looked too plain without them, so I went ahead did the sprinkling. The prep was easy, just use some degreaser on the really bad grease/oil/gas stains, and then use the acid/etcher, which roughens the concrete surface for a good adhesion. Let it dry real overnight, not a problem in Phoenix or Las Vegas, then paint the next day, that is a problem in Phoenix, especially during the summer. Once you've mixed the epoxy, you've got a limited amount of working time before it sets up. Just follow the directions and have at it!
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    Ive done a few floors with epoxy. We always use muratic acid to etch the concrete and lift the stains. Be careful with this stuff!!!! wear good rubber gloves, and use baking soda and water to neutralize it. DONT get it on your skin or breathe the fumes!!!! Once youve painted, setup fans blowing out of the garage to help with the smell. Hope this helps, Dave
    Aug 2002
    1,605
    typically all epoxies take 7 days to fully cure
    but that doesnt mean you have to stay off it for a week...........epoxies can withstand moderate traffic after 24 hrs.......
    as far as doing only half at a time, i don't see any problem with "cold joints" (or lap marks) between sections.......I would be concerned with adhesion if the two halves were done more than a week apart or the fully cured time.
    the main thing is deciding product...there are tons out there each with there own particular specs on prep....but bottomline, all of them are pretty mindless to apply
    you don't have to be a brain surgeon to be a painter......
    one more thing...as far as "pot life"....the more vigoriously you mix the kit, the faster it will "kick" or set up, appropiate thinners can slow this process if you plan on doing it in dry/hot conditions
    btw, the 2 component aliphatic blah blah, i talk about is commonly used in exterior applications under county state and federal specs in El Centro...it's well known for color and gloss retention
    Good luck
    Lancaster, PA
    1,738
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Quote Originally Posted by mymint87
    I always wondered what happens when you pull the car in with snow on the tires....instant back door?
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Trike Dude is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2004
    Las Vegas
    180
    Quote Originally Posted by 250rAL
    That is a very good question!
    1985 ATC350X
    "El Duderino if your not into the whole brevity thing"
    xd 200x is offline Just Too Addicted Arm chair racerJust too addicted
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Quote Originally Posted by blue27
    I saw that in a magazine, I was going to post about it. But looks like he beat me to it
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Sep 2005
    Massachusetts
    1,272
    I was watching one of those sunday afternoon mechanic shows on spike tv and they did the ucoatit to the garage. The end result was very nice. Might be worth doing.
    2000 Rm250
    1985 IT200
    2003 suzuki sv1000s
    2008 polaris outlaw 525s
    Bartlett TN
    3,083
    Yeah I have already thought about doing this to my garage too. Problem is I have a 3 car garage so its gonna cost me big! But I figured I could do the section the cars are in first and then move the trikes over once completed and put them on the other side to do the 3rd car garage. Hey Minty......thanks for the info man, you always did know your paints hehe
    86-87 Tecate ROCK!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    The best way is to do as the directions say.This will give your new the floor the best results.Do it all at once or don't do it at all.Till you have all the money that is.
    I have been thinking of doing this to my garage as well.
