Probably a broken wire. the run switch and the key switch are connected in parallel. They kill the motor by grounding the ignition. If you can run a Ohm Meter or continuity tester you should be able to find the break. The other common possibility is that there is crap in the kill switch, keeping it from making contact
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
