Results 1 to 2 of 2
Thread: my 350x updates
    Jan 2005
    Wasteland Michigan
    149
    my 350x updates
    getting ready for trike fest
    well ive installed the 85 all balls steering stem kit in my 86 and it fit with no problems you only use their seals on the lower bearing and a O.E. seal on the top.
    installed the new dunlop front tire and wheel bearings.
    made braided brake lines front and rear, used a newer 400ex front master with a brake light switch and a goodridge banjo bolt with a brake switch. got a led tail light off a 450R ( it fit in the stock tail light bracket too ) and got it all working it looks sweet.
    adjusted the valves and decompression cable ( starts sooo much nicer )
    new clutch perch with quick adjust, new thumb throttle, the new chain is on the way.
    painted lots of little things.
    now for the only part i hate doing cleaning and polishing
    larry
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    Sounds good! Hope to see ya there.
    -Mike
