Results 1 to 6 of 6
Thread: which front ends w/85 '-86 ' 250R?
    Feb 2006
    connecticut
    95
    i was wonering if someone could tell me if any other front ends work on the 85/86 250R's. i heard 350X's? do eairlier year 250R's work? sold my 350X the other day so its time to start building a 250R from scratch. this way it will be exactly the way i want it. thanks
    Feb 2006
    connecticut
    95
    can anyone help?
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    I think only 85/86 250r forks work on 85/86 R's. I hope that helps.
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
    Pennsylvannia
    1,147
    You'd be better off using an '85 or '86 R front end. 350X forks are alot smaller and I'm pretty sure they have less travel. Everything on the R seems to be beefier than the stuff on the X.
    '85 250SX - My first ever trike and my pride and joy
    **Check Out The Whole SX Project Here!!**
    '85 350X - 10:1 Piston, performance cam, '86 engline/carb
    '85 Powervalved Tri-Z - Fully modded - Soon to have a Corey Sprock 310 kit
    '85 250R - Began the modification process. This bike is going to scream! -295cc kit, Ported, Drag intake, 40mil Keihin, VForce reeds, shaved head, PT High Rev pipe, Fat Boy 2 Silencer, +4 Durablue axle, +2 swinger-
    Rancho Cucamonga, Ca
    228
    350X is too small. No reason to run that fork anyway. The R fork is stiffer, and more travel, much better working. 85/86R forks are the best trike forks ever made.
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Feb 2006
    connecticut
    95
    thanks guys!
