Results 1 to 11 of 11
Thread: How to redue a 1984 Tecate Gas Tank
    Apr 2006
    Fort Wayne, IN
    88
    I want to redue my gas tank but I don't know how to paint the plastic or make it stick for that matter. I saw someone with a gas tank cover for thiers and that looked alright if I had to, but I would like to some how have it painted or redone some how. Thnaks
    Jan 2005
    Great Bend
    704
    well you can use krylon fusion plastic paint or you can sand/polish it to get the scratches and scuffs out.
    this method was used on a fender, I dont know if you will get the same results on a fuel tank.http://www.3wheelerworldforums.com/s...anding+plastic
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Apr 2006
    Fort Wayne, IN
    88
    Krylon fusion plastic paint doesn't have a green that is close to the kawasaki green, I wish they did though
    Pennsylvannia
    1,147
    Is the Kawi tank plastic? I've never owned a Tecate, but I think they are plastic. You can not paint a plastic gas tank without the paint bubbling off after some time. You would have to Red Kote the inside of the tank before you painted it.
    Newfoundland
    5,280
    Greenlightning on this board painted his tank and some others. Matched the colour to the fenders really well. The inside of the tank needs to be sealed with a product called Kreem to keep the gas vapors from seeping though and bubbling the paint. You use Krylon or some other plastic primer that promotes bonding and then automotive paint can be used.
    Search for "Greenlightning"
    James.
    Oct 2005
    saratoga, ny
    2,819
    plastic primer...
    i painted the tank on my bike, i used a primer specificaly for plastic then shot it with some grabber green high temp paint, came out nice i think.
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    [CODE]You can not paint a plastic gas tank without the paint bubbling off after some time[/CODE]
    Bull. Mine has not bubbled, peeled or chipped on my R. I have even spilled gas on it and has not eaten it off. You guys are not prepping surfaces correctly.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Get a vinyl tank cover from Ebay
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Apr 2006
    Fort Wayne, IN
    88
    Been looking for the vinyl tank cover, but man I just can't get myself to like them, I just bought this trike and whoever had before me tried to paint it and it had two layers. A black rough layer against the plastic tank, and than the green top coat. Whatever the black stuff is, it sticks pretty good.
    Jul 2003
    indiana
    892
    You can paint a tank if you do the correct prep work and use the right materials. Right does not always mean the cheap ones. Now I know from experience that you can wet sand a 84-85 T3 tank all day and it will not come back to the brilliant green that it once was. Once they are faded they stay faded. They will look better but not great.
    Apr 2006
    oakridge oregon
    124
    you can sand blast the gas tank with fine green diamond sand and paint it with industrial acrilic urathane.three coats color and two coats clear work well. the paint is gas and alcohol proof. my tank has been painted for 3 years with no problems.color was easy to match
