Results 1 to 15 of 23
Thread: 250r or 200x FORK TUBES(not triple tree) fit on a 250sx?
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Exclamation 250r or 200x FORK TUBES(not triple tree) fit on a 250sx?
    Will the fork tubes out of a 250r or a 200x fit in the stock triple tree of a 250sx?? HELP!
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    crd00's Avatar
    Feb 2006
    323
    so no one knows the answer to this question?
    Pennsylvannia
    1,147
    I'm pretty sure that the 250R ones are way too big, but I'm not sure about the 200X ones... I've never owned one so I don't know the size of the tubes.
    crd00's Avatar
    Feb 2006
    323
    Thank you for your reply anyone else?
    crd00's Avatar
    Feb 2006
    323
    A lot of people have 200x's and 250sx's and no one knows if they fit??????????I really need help here so I can save money
    Pennsylvannia
    1,147
    250sxwheeliepop should know because he put a 200X front end on his 250SX. I'm assuming that the forks from the 200X don't fit into the 250SX tripples because when you do a 200X front end conversion on a 250SX, you need to put on the 200X tripples and everything.. you can't just slide the forks right on.
    May 2005
    Dorset United Kingdom
    1,408
    Nouse, can you measure the diameter of the stock SX forks? then they can be matched up to some similar.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Pennsylvannia
    1,147
    Yeah.. I'll measure them whenever I get home from school. They are pretty tiny..
    staceyl200's Avatar
    staceyl200 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2005
    South Wales UK
    253
    Just measured my forks and the 250R are 39mm dia and the 200X forks are 33mm dia (the tubes) Hope this helps
    Cheers
    stacey
    05 TRX 450R HRC (Black)
    86 ATC 250R
    83 ATC 200X
    May 2005
    1,408
    85 Z ones mic up at 35mm
    Nov 2004
    Atlanta TX 3-states area
    1,592
    I have seen a set of 200X forks on 250SX triple clamps before. I didnt ride it so I dont know how the overall worked out but I know that they were on it and it was working ok
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    crd00's Avatar
    Feb 2006
    323
    does anyone know of this for sure? because i really need to find out
    crd00's Avatar
    Feb 2006
    323
    I just measured my tubes and they are 33mm....correct me if im wrong
    Theres definetly 1000 people on this site whos had a 200x or a 250sx at some point and no one can tell me this simple question? All I need to know is if the frok tubes off a 200x will slip right in a 250sx triple tree because Im buying 200x tubes but I dont want to buy the tree if I dont need it
    Nov 2005
    NY newyork
    7
    Can someone just answer him because I'm tired of lookig at this post. Its only a simple question. I cant answer it because Ive only had yamaha's
    May 2005
    1,408
    Be patient, people arent here to answer all the time.
    By the sounds of it 200x forks will slide right in, but remember you will need the entire braking system off the X too from master cylinder to caliper.
