Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: 250r or 200x FORK TUBES(not triple tree) fit on a 250sx?
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Hopefully they will slide right in but the only reason im in such a hurry is because my sale is being held up
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    crd00's Avatar
    Feb 2006
    323
    anyone?
    springville, PA
    6,185
    pms are cleaned out
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2005
    Lockport, NY
    2,395
    Working on a 250sx conversion right now. Dont believe that the 200x forks will work on 250sx tree's. I bought a 200x front end and i am in the process of swapping. Then again i have not a fricking clue on how your going to mount up a rim and brakes. So dont know what your plans are other than riding on forks.
    springville, PA
    6,185
    when you put the 200x forks the sx parts drop off and you just put a 200x caliper, axel and so on on it.
    Nate
    R.I.P HRR
    Nov 2002
    Kirkville, NY
    3,831
    Are your forks bent? Corect me if I am wrong but if you are going for the narrow front tire then you would want to run the 200x tripple tree otherwise your shocks will be wider then the 200x axle.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    They slide right in the 250SX triples. It is a poor mans conversion and requires spacers to be fabricated to center whatever hub you chose to run, stock SX X or R all fit the SX axle. You don't HAVE to run brakes and good ones are tough to find anyhow. Your front end will be a bit higher and will have better suspension but I would do the whole swap if it were me....
    crd00's Avatar
    Feb 2006
    323
    ok thanks guys, I'm in the process of buying the whole front end now anyways.Its soon getting shipped
