Results 1 to 9 of 9
Thread: TriMoto 200 Questions
    Apr 2006
    Northern New Hampshire
    Question TriMoto 200 Questions
    Hi,
    I just got a mid 80's Yamaha TriMoto 200 (4 stroke) given to me and I have a few questions about it. First what kind of oil does it take (weight/type) and second what would cause it to smoke alot? It starts right up even when cold very easily but once warm, it smokes white smoke like crazy. I haven't ridden it yet so maybe it just needs to be run more or is there something wrong with it?? I've already cleaned the carb and it's in good working order. Any Ideas?
    Thanks
    OldTriMoto
    Oct 2005
    North Branch, MI
    196
    as for oil, 10w30 will work, 5w30 will work too. as long as its clean. as for the smoke, maybe time for a new topend. does it have good compression?
    Tionesta, PA
    5,747
    White smoke normally means water - try draining the tank (if you haven't already) and putting fresh gas in it and see if that helps.
    Apr 2006
    Thanks for the help. I haven't tested the compression yet (my compression tester only fits cars and sleds) but it seems to be good. I wouldn't think it would start as good as it does if it had poor compression. I've put new gas in (and drained the tank) so it isn't that. I'll just have to ride it more and see what happens. It's a freebee so I'm not too concerned. Thanks again
    OldTriMoto
    Jun 2006
    courtenay bc canada
    4
    i have a yamahauler 1983 200. (same thing)
    i just got it back from my friend who had it for 2 years and now it smokes alot and there is a ticking sound. Also, when i was riding for about half an hour it started to make a squeaking sound from the cylinder!. Then it started to seize and lose all power.
    it still runs and starts, but it seems to be seizing slowly for some reason.
    where can i find a new top end?
    May 2005
    Dorset United Kingdom
    1,408
    You checked the oil?
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Jun 2006
    courtenay bc canada
    4
    good idea. the oil level was fine but im gonna change it right now . ill post what happens.
    Jun 2006
    courtenay bc canada
    4
    well i changed the oil. the drain plug is on the left side by the shifter. there is a screen in there that was totally blocked with oil,and a spring. the oil that drained out looked terrible. i cleaned the screen, and put it all back togethor. When started it ran smokey and i only made it 30 feet before it just quit and wouldnt start again. now when i pull the starter cord it feels as if theres no compression at all!
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    I have an 85 200ERN and I change oil every 3 months because the local shop said these are piccky about clean oil... Good Luck
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
