Results 1 to 8 of 8
Thread: Lesson in Acceleration
    Dec 2002
    Kansas
    2,387
    * One NHRA Top Fuel dragster 500 cubic inch Hemi engine makes more
    horsepower than all the cars in the first four rows at the Daytona 500.
    * Under full throttle, a Top Fuel dragster engine consumes 1= gallons of
    nitro methane per second; a fully loaded 747 consumes jet fuel at the
    same rate with 25% less energy being produced.
    * A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive
    the dragster's supercharger.
    * With 3000 CFM of air being rammed in by the supercharger on overdrive,
    the fuel mixture is compressed into a near-solid form before ignition.
    * Cylinders run on the verge of hydraulic lock at full throttle.
    * At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the
    flame front temperature measures 7050 degrees F.
    * Nitro methane burns yellow. The spectacular white flame seen above the
    stacks at night is raw burning hydrogen, dissociated from atmospheric
    water vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. This is the output of
    an arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After 1/2
    way, the engine is dieseling from compression plus the glow of exhaust
    valves at 1400 degrees F. The engine can only be shut down by cutting
    the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up
    in the affected cylinders and then explodes with sufficient force to
    blow cylinder heads off the block in pieces or split the block in half.
    * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at
    an average of over 4G's. In order to reach 200 mph well before
    half-track, the launch acceleration approaches 8G's.
    * Dragsters reach over 300 miles per hour before you have completed
    reading this sentence.
    * Top Fuel Engines turn approximately 540 revolutions from light to
    light.
    * Including the burnout the engine must only survive 900 revolutions
    under load.
    * The redline is actually quite high at 9500 rpm.
    * The Bottom Line; assuming all the equipment is paid off, the crew
    worked for free, and if,for once NOTHING BLOWS UP, each run costs an
    estimated $1,000.00 per second. The current Top Fuel dragster elapsed
    time record is 4.441 seconds for the quarter mile (10/05/03, Tony
    Schumacher).
    * The top speed record is 333.00 mph (533 km/h) as measured over the
    last 66' of the run (09/28/03 Doug Kalitta).
    Putting all of this into perspective for you " bikers " : You are riding the
    average $250,000 Honda MotoGP bike. Over a mile up the road, a Top Fuel
    dragster is staged and ready to launch down a quarter mile strip as you
    pass. You have the advantage of a flying start. You run the RC211V hard
    up through the gears and blast across the starting line and past the
    dragster at an honest 200 mph (293 ft/sec). The 'tree'goes green for
    both of you at that moment. The dragster launches and starts after you.
    You keep your wrist cranked hard, but you hear an incredibly brutal
    whine that sears your eardrums and within 3 seconds the dragster catches
    and passes you. He beats you to the finish line, a quarter mile away
    from where you just passed him.
    Think about it, from a standing start, the dragster had spotted you 200
    mph and not only caught, but nearly blasted you off the road when he
    passed you within a mere 1320 foot long race course.
    That, folks, is acceleration .
    I had the RIGHT to remain silent, I didn't have the ability!
    Aromas, CA
    109
    That is just awesome. Incredible! It is my understanding they accelerate from 0-60 in oh 0.7 seconds
    Poplar, WI
    531
    Thats awsome...although my mini van does that LMAO...its got a HEMI.
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    May 2005
    Southern NH
    1,489
    I would kill to go for just ONE run in one of those things! I go to the drags every year and they are incredible to see!!!!
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Feb 2005
    Oregon
    772
    The exhaust from a top fuel at full throttle creates over 800lbs of down force. Like I have said on many auto forums where the ricers go, nothing is faster than a domestic V8.
    They also have a Natural aspirated class in top fuel, those cars are makin 5,000 hp with no forced induction. I belive the forced induction cars are up to 7,000 hp.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Washingtons Crossing, Pa.
    2,977
    That was very enlightening wrench ..... thanks.
    Jun 2003
    Lake George, New York
    1,732
    Those are some crazy facts..
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    I saw that list posted on one of my car forums a couple of years ago, but the facts still stagger me. I can't even fathom it...
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
