Results 1 to 11 of 11
Thread: Clutches (quick idea)
    Jan 2005
    Miami,Fl
    73
    my 200s clutches are a 4 pack and I have an extra set of clutch discs...I was wondering if I could make it a 5 pack? the clutches were slipping so Im replacing them. and there are more mods to come so I want to be sure I get as much to the tires as possiable. The engine is apart as we speak and I wanted some input before I put it together and either "Fly or Die"
    Thanks for you time
    Tionesta, PA
    5,747
    If it comes with 4 discs and you replace it with 5 - you will have clearance issues, or you won't be able to put it back together - (too much spring tension). Go with the factory specs on # or discs and you'll be fine. You are not gonna increase the power enough to slip new discs.
    Jan 2005
    Miami,Fl
    73
    Alright, 4 it is...it was a idea, I didn't day it was a good one
    Thanks
    Tionesta, PA
    5,747
    86200s;
    Out of curiosity, how much do you weight?
    Jan 2005
    Miami,Fl
    73
    bout 140lbs
    Jan 2005
    Miami,Fl
    73
    lol...maybe if I was 200+ it would be a good idea
    Tionesta, PA
    5,747
    OK - if you are upping the horsepower to say 16HP and you weighed something like 350 lbs - then you may be concerned about the clutch, but rest assured, you'll be fine.
    Jan 2005
    Miami,Fl
    73
    Im prob at around 16, 17 hp right now...but I think your right, Im gonna put it back together now
    Jan 2005
    Miami,Fl
    73
    I did 5 pack, couldn't help it...but it pulls hard 0 slip and no problems I guess its a good idea so far...when I put the other Ported head, cam, and xr200 carb I think it couldn't hurt to have the 5 pack setup...to ensure 0 slip
    May 2005
    Dorset United Kingdom
    1,408
    Quote Originally Posted by 86200s
    Lmao What mods did you say again?
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Jan 2005
    Miami,Fl
    73
    hahaha...nothing I am or if not will be VERY soon, .20 over, 10:25:1 piston, xr200 cam, 200x carb, straight pipe, Port and Polish and soon to come and extreme p&p head with Quelches to raise compression to bout 12:1 and a powroll cam and xr200 carb
