Results 1 to 8 of 8
Thread: Good News / Bad News
    N5HNY's Avatar
    N5HNY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Arkansas
    180
    Well folks, I got the 86' Big Red running today. It still needs other odd and ends stuff, but I was able to ride it around the yard. It pulled strong too.
    The bad news is that I think it has tranny problems. If you put it neutral, it makes a grinding noise. It will go into reverse but it makes that same grinding noise.
    Super Low through 2nd seem fine. There is some noise in 3rd and it will just slam on the brakes in 4th. I mean like it locks up or something. But then it will try to move out with some throttle. I t never kills the engine at any time. Very strange.
    Vance
    NE Arkansas
    2,344
    Hmm, congrats on getting it running! Dunno bout the problems though. Could adjustments of the auto clutch help? Does it still run ok even though it's grinding?
    My Rags
    N5HNY's Avatar
    Jan 2004
    Arkansas
    180
    Yeah I have been thinking it is a clutch problem. When the engine is idled down, it stops the grinding sound. Rev it up a bit and the grinding returns.
    The machine tries to move forward even in neutral. You can see it trying to move on it's own from time to time.
    Vance
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    yeah man i have a ytm200 it will grind only in 1st gear becuase its gone but everyting else is excellent dont worry about it have some fun man!
    N5HNY's Avatar
    Jan 2004
    Arkansas
    180
    Yeah I was telling my father-in-law that. I said,"Hey it works in three forward gears so I CAN ride."
    The funny thing is that it GOES into gear it just makes that griding noise. I tried to adjust the clutch but it seems the adjuster will not go in any farther.
    Now I have to fix the idle problem. It idles a bit high even with the idle mixture screw all the way in. Maybe I need to go ahead and put the air box back on and then make the adjustments.
    It sure was sweet riding around the yard yesterday.
    Vance
    Apr 2006
    Cornell Illinois
    31
    Sounds fun keep it going!
    na
    5,702
    i dont know too much about the big red,but it sounds like a broken shift fork maybe?
    Proudly NOT a member of
    "Team on the Teat"
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Sounds like your clutch is grabbing to hard, or like moshman said, sounds like a shifting fork too.
    TF 07,08,09,10,11,12,13,14!
