I was wondering how many members have twist throttles on their trikes. My hand starts to tingle and I was thinking of putting on a twist throttle on my 200x.
My rides
85 200x
06 Rancher
My rides
85 200x
06 Rancher
Not a real good idea to put a twist throttle on a trike. IMO. Not unless you have alot of experience with them.
I dislike twist, I myself perfer thumb. I found that the main thing is to find a comfortable position for the thumb throttle assy. When I raced GNCC (2+hrs long event) I would not tighten the thumb throttler screws to tight, thight enough that it would not move but... that i could hit or grab ahold and twist real hard to change the postion to give my arm a break if started to "pump up". This is a good thing to do on all you lever assy (clutch/Frt Brake) because if you do roll it over or smack a tree hard enough the assy will spin around on the bars instead of breaking. Twist i had aproblem with bouncing around and applying the gas when I didn't want it and the biggest issue was trying to hold on when a hill climb attempt went bad. But everyone has there own opinion. I was always told if you started riding bikes then switched to ATVs you would perfer twist, but if starting out on thumb its hard to switch to twist.
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
I don't mind twist throttles, but Id rather thumb. I've used both of them in my past bikes. The thing about twist throttles are is that they stick and could flick you 20ft away from the bikeI know someone whos put a twist on their trike and it stuck and the bike slammed into cinder blocks and the bike got bet to crap. So I'd just stick with the thumb
WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
Thats just a case of bad maintenace by the sounds of it Chris.
I'd like to switch to a thumb throttle on my Tecate. Twists isn't hard to use but the woods riding and hill climbing I do I'd feel better running a thumb throttle.
James
I personally couldn't disagree more..... I have a twist throttle on my 250R and I wouldn't EVER go to a thumb. On trikes, especialy racing ones like the 250cc's, you lean into corners, sometimes a LOT. I race around corners sometimes like the old school flat track racers! One leg hanging over the side and such. So a trist throttle is much eisier to hold onto. When just you thumb is touching it can easily slip right off.......Originally Posted by chrisr200x
For quads (except racing purposes) I prefer a thumb, but on trikes and bikes, twist all the way.........![]()
-Devin
"I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
I would never use a thumb throttle.
85 atc 250r;
PSI porting & head mods
fmf pipe & silencer
boysen rad valve & reeds
38mm air stryker
Keep the thumb, twists are a royall pain in dee arse
well I recently put a twist on my 85 200s and I love it. I get a better response out of the bike. Now if you are not that experienced then I would agree it could get hairy. I know its all a personal matter of preference though...
"Trikes are like Wifes, only REAL men can handle them!"
85 Honda 350x
85 Honda 200x modded a little
85 Honda 200s
87 Honda 125trx
It is all a mater of preference as to what you like and how and where you ride. Open areas and flat tracking a twist might do you fine. Less fatigue on the thumb. If you are going to run hills and tight trail riding I would stay with the thumb. It gets real hairy with a twist in tight trails and especially on hills. jmo
Parts for sale
85 KX250 Roller with engine
KDX motor
2004 E-Ton Viper 50 Needs work
Honda 87 Fat Cat Roller
Honda 200m motor
Honda 110. 80 frame 82 motor For parts. Runs.
Honda 84 ATC 70 Roller Cheap.
XR75 complete bike
XR80 parts
Yamaha 225dx parts.
Honda 84 200es parts Good bottom end. (quad conversion front end)
Kawasaki 93 KX80 Motor (needs piston & bore)
Yamaha 88 YZ125 cases
Suzuki 85-87 LT230s 2 complete parts bikes.
Honda 83-85 200x Parts
Honda 86-87 200x Parts
I have been thinking of trying a throttle extension first. The guy I got the 200x from gave me one. I just need to find it.
Twist on everything.
2000 Rm250
1985 IT200
2003 suzuki sv1000s
2008 polaris outlaw 525s
For a real cheap thumb throttle extension use a discharged 12ga shell, work perfect. I grew up on a farm and that was on everything from teh Big Red to the Pro-hauler.
Barry
I have a small circle track below my house (the straight aways are probably 200 yards or so), and I go pretty fast around the corners and its really easy with a thumb throttle. I lean way into the turn as well, and its still really easy with a thumb throttle.. I definately don't feel like I'm going to slip right off.Originally Posted by 250r'en +TCB
