Results 16 to 30 of 32
Thread: Won't Start
    Apr 2006
    Bronco Country
    64
    Hey, thanks guys. I already took the carb apart today, it was pretty dang clean. Put it back together, it still didnt work. Also, we blew compressed air through the jets, and they werent clogged. I will try some ether/gas directly into the carb, prob. next weekend though. So does this problem I'm having sound familiar to anyone? Do you know what the cause may be, since the carb was clean? Thanks
    BTW, it sounds like it really wants to start when we try, it just never turns over.
    Go Broncos!
    BTW, 1984 Honda 200M
    Gunnar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Rose City
    181
    fresh gas definately. Could be moisture in the tank from sitting all winter, especially if living in a cold climate. try some premium gas plus a little gas dry.
    might not be recomended but I will also dump a thimble of gas into the spark plug hole if its really hard to start. sometimes it just needs that first jump.
    Baltimore, MD
    6,088
    Does the 200 have a pull starter? Have you just tried to pull start the crap out of it. Are you saying the engine is locked up, that it won't turn over at all? If it has fuel, spark and air it should start. The only thing I could think of is the timing is off or one of your valves are sticking. Was your spark plug wet with fuel when you were starting? Was there any indication that gas was getting to the top of the piston and the spark plug? If you have an intake valve sticking shut, you wouldn't be getting fuel to the plug. If the intake valve is sticking open you wouldn't be getting any compression. If the intake valve is sticking shut, you wouldn't be getting any fuel or air movement through they cylinder. Have you checked your valve adjustments?
    Apr 2006
    Bronco Country
    64
    Hello. It does have a pull starter, and we tried it a ton, still no go. And when I say it wont turn over, it just wont start. Like it is cranking, and sounds like it wants to start, but it just doesnt quite make it. Air comes out of the exhaust when we try to start it. Also, each time we took the spark plug out it was pretty wet, like black kinda. I havent checked the valve adjustments, I dont know how. Thanks.
    Go Broncos!
    Baltimore, MD
    6,088
    Have you tried starting it without the airfilter in it? You need fuel, air and spark. You said you have spark, seems like you have fuel, maybe not enough air. Try removing airbox lid and airfilter and see what happens.
    Apr 2006
    Bronco Country
    64
    Alright, thanks. I will possibly try that tomorrow. You say that with those 3 things, it should start up every time? Thanks for the help.
    Derek
    Go Broncos!
    YTM200BOY's Avatar
    YTM200BOY is offline All your base are belong to us???? Arm chair racerNew to the board
    Sep 2005
    Illinios
    37
    lol man me and my dad have a 83 ytm200ek electric start is shot "we got a puller starter only" and we are having the exact same problem..... it blows doesnt it! if *Edited* find anything that works plz help me and o yeah the air unit gettin bak on the bike doesnt make a differeence i have tries like 40 ideas lol...-Joe
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    We got spark and the compression seems a bit different then when it ran ay?? also the plug is black and wet is this what you have?
    Apr 2006
    Bronco Country
    64
    Hey guys, I put my finger over the spark plug and tried, and it blew my finger off pretty good. Also, I took off the air filter and tried starting it, still didnt start. What could it be?
    Go Broncos!
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    try pulling it with a quad / trike / truck / whatever in 3rd gear at about 10 MPH and see if it starts, leave the air filter off and make sure you have spark before you start dragging it around.
    Duluth MN
    803
    the first thing you should have done is replace the spark plug. if that dont work try to darrel pull start way
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    b182m if the truck / car / quad pulling way works plz respond i would like mine running also lol..
    Apr 2006
    Bronco Country
    64
    K, I will try it maybe today or tomorrow. Thanks guys. Derek.
    Also, by now are you guys ruling out a damaged engine? Cuz your suggestions sound like just something small that's wrong. Is this correct?
    Go Broncos!
    Apr 2006
    Bronco Country
    64
    !!!!!!!!!!! Yes, it's alive!!! So I got a new spark plug today, popped that baby in, started on the very first try. Runs like a beauty!!!! I dont get it, the old spark plug had a spark...oh well, it runs!!!
    YTM200BOY, you did try a new spark plug, right?
    Thanks for all the help everyone, I appreciate it.
    Derek
    Go Broncos!
  15. #30
    YTM200BOY's Avatar
    Sep 2005
    Illinios
    37
    o bull crap lol SON OF A Bizzle -lol are *Edited* serious??? my plug is a ngk stock plug but its black and crappy lol so i went to autozone and they said a crossreference was this champion plug and i have 2 new ones and the ngk is current in it but i have tried the other champion new *Edited**Edited* so damn *Edited* lol.... good though.......4 *Edited* lol
