Results 1 to 2 of 2
Thread: Tranny Questions
    N5HNY's Avatar
    N5HNY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Arkansas
    180
    Tranny Questions
    My 86' Big Red has some transmission issues.
    It tends to grind gears in neutral, reverse, and SL. If you sit at idle in neutral it won't grind til you rev it a little so I guess the clutch is working ?
    I am afraid my shift forks are bent or worn.
    I can ride in 2nd through 4th OK. But if I sit in idle in any of those gears it feels like it is trying to move forward and then try to back up a little. Very strange.
    Vance
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    I can say that I have no knowledge whatsoever of your clutch setup, but with a basic analitical understanding of clutch concepts, I would look there first. My theory...at idle, nothing is being asked of your clutch, but once you attempt to produce motion, your clutch is in the mix. Just my thoughts on the subject...any experts care to chime in here?
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
