Results 1 to 8 of 8
Thread: 350x carb on a 250sx
    Aug 2005
    Lockport, NY
    2,395
    need an idea on main and idle jet that i need to use on a setup for a 350x carb in my 85 250sx. 130 main???
    Dec 2005
    Tulare California
    10
    250sx/350x
    If you throw a 350x carb on your sx let me know how it works out. I tryed one on my 250sx here and the idle slowly crept up while at idle. I think it had a 132 main jet and a 38 slow.
    Honda 350x sold
    Honda 200x sold
    Honda 250r sold
    1985 Honda 250r
    Unless you change the exhaust and open up the airbox then put the stock SX jets in the 350X carb. If you do run an AM exhaust and no air box lid then the stock 350X jets will work fine but the main jet could stand to be upsized a size or 2.
    springville, PA
    6,185
    If the machine is stock go with stock jets. Mine with the pipe, filter, no air box lid still runs rich with a 135 main.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2005
    Lockport, NY
    2,395
    thanks dirtcrasher. My sx has given me carb troubles ever since. one of the holes in the original sx carb is drilled crooked. I have seen this before on huge lots of mikuni's. Does the 350x carb greatly improve the SX? Can anyone tell me stock 85' SX carb settings? Jets, clip position and others?
    springville, PA
    6,185
    and yes even if it is pure stock it makes a great difference in the machine. When I had it on mine pure stock like I had the 135 main and all the other stuff was 350x positions. And as long as you played with the A/F screw it would idle fine.
    Nate
    R.I.P HRR
    Aug 2005
    Lockport, NY
    2,395
    any body on stock 85 sx carb settings?????
    springville, PA
    6,185
    Say hello to bikebandit.com. http://houseofmotorcycles.bikebandit...e~ATC250SX.asp
    Scroll al the way down and it will show the jet sizes next to the name
    Nate
    R.I.P HRR
