Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Mojave powered Tecate?
    Rancho Cucamonga, Ca
    228
    The other 2 are I believe #11 Jackie Meadows, and #64 Charlie Sheppard. pm me if you are interested in mojave parts...
    own:
    1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
    1986 250R- mild porting, carb mods (Clean!)
    1985 350X- all stock (super clean!!)
    1985 350x- desert project in the works
    1986 250sx- Mostly stock
    1985 200x- (pretty clean mostly stock)
    1985 Yamaha tri zinger 60
    Apr 2006
    Rushford MN
    141
    Not really looking for a whole lot of stuff right now, kinda broke, and the T3 needs some money first I want to do it, just not in the real near future. Just outta curiousity, what do you have? I think the EX500 would be really kick ass! If I am correct that is the Ninja motor right?
    Joe
    Newfoundland
    5,280
    I'd go for the Ninja 250 swap. That thing has a 14k redline!
    James
    Feb 2005
    Orchard Colorado
    659
    Quote Originally Posted by BigGreenMachine
    James
    The problem with the 250 Ninja is that it feels like 14hp unless you keep it peged at 14,000. The EX has more bottom end because of the cc's and redlines around 9,500.
    Oct 2005
    saratoga, ny
    2,819
    i wanna morph a tecate motor into a blaster frame...extremely light, gutwrenching power, what a combination.
    Apr 2006
    Rushford MN
    141
    If your going to do somthing like that I would look for a newer KX250 motor. The Tecates are counterbalanced anyways so your not gain much vibration, and the power output on some of the mid ninties ones was in the 50hp range!!! Oh and they are cheap, and your not gonna wreck a good Tecate.
    tecate kid
    Apr 2006
    Rushford MN
    141
    As for the 250, I want somthing that is lightweight, makes good power, and has a fairly large aftermarket. I really don't think the 250 motor would be a good choice for a woods runner, but if I was building one for the dunes that would definatly be the way to go. If I am correct thise are twins aren't they?
    tecate kid
    Newfoundland
    5,280
    Yes they are twins and your definately right bigbore about the low end power of the 500 compared to the 250. Its just the 250 revability would stay in theme with the Tecate.
    Personally Trike Kid, I'd stick the 45 tooth rear sprocket on your 84 T3 and call it a day. You will gain loads of bottom end with that sprocket. Throw some 22 inch Holeshots on the rear, get your shock rebuilt and go have fun.
    FYI, I may have my 45 tooth sprocket for sale in the near future.
    Dec 2002
    749
    I considered doing the swap when I had my 86 T3. It would take way to much hacking of the T3 frame to make the motor fit, so I just bought a 95 KX250 motor and installed it. It definitly ripped!
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Ontario, CANADA
    4,538
    Virgil, does a 95 KX250 bolt right in no questions asked? If so thats something I never knew!
    Power!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Jul 2003
    Ontario Canada
    813
    The EX500 is a great motor, very very reliable and they make mad amounts of torque for just a 500 twin, plus, you have alot of options available for modding them (pipes, cams, i think you can even get a 525 big bore kit for them)
    good luck with the project and let us know what you do.
    Curtis
    Currently Trikeless- but I have a LT250R
    Apr 2006
    Rushford MN
    141
    How much hacking was involved? I know the tops of them are a whole lot bigger but is there really that much hacking that needs to be done? Oh and like I have said I am just testing the water on this project, not really ready to spend the money needed to finish it.
    tecate kid
