Results 1 to 15 of 18
Thread: ouch
    Apr 2006
    MINNESOTA
    39
    ouch
    ok now was out on tri moto and ever thing was good got to the top of a hill and she die on me no big deal pull her she sounded like i had her all the way open..
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    is it out of gas? Mine does that just before it runs out. Check the gas clean the carb and if thats not it then it could be crank seals.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
    Oct 2005
    Pennsylvania
    863
    Agreed ---Its out of gas!!!!!------Yamahas feeble attempt at a fuel gauge-lol
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Apr 2006
    MINNESOTA
    39
    *&%^&*r$^%$
    gas is top off and still as soon as i pull it she runin like a bat out of hell
    Nov 2004
    northern arizona
    58
    check the throttle circuit/cable for it binding or ???? carb slide stuck!
    Sep 2005
    Massachusetts
    1,272
    Air leak?????
    2000 Rm250
    1985 IT200
    2003 suzuki sv1000s
    2008 polaris outlaw 525s
    Apr 2006
    MINNESOTA
    39
    Run you *&T(^(&^$^%^$%^%#%$@
    Apr 2006
    MINNESOTA
    39
    throttle has no sping when i just tryed to start her how can i fix this help!!
    Aug 2004
    Ab Canada
    4,368
    No springh back to it? Check make sure the Cap the throttle cable go's though on the top of the carb didnt come loose or the slide pop out.....or the slides in backwards.
    1985 Tri-Z-
    Apr 2006
    MINNESOTA
    39
    where i put that big ill fix it grrrrrrrrrrrrrrrrr
    CT
    40
    mine did that too, turned out to be a clogged pilot jet
    Apr 2006
    MINNESOTA
    39
    gonna tear her down and see wtf is wong
    Apr 2006
    MINNESOTA
    39
    well we have spark gas going to the carb but no go was starting 1st pull for a week but wont start at all gotta be the crab huh??
    Nov 2005
    bryan ohio
    221
    After you play with the carb and get that alll straightened out , if it still not right try starting it and spraying carb cleaner or wd40 around the intake,head and where the jug mounts to the bottom end and see if it slows the motor down. if it does thats where your airleak is.
    1 yt175
    1991 blaster
    Apr 2006
    MINNESOTA
    39
    need a pic of a tri moto 175 carb hook up there a litte brass thing where a hoes hooks up on the back hmm dont member it being there when i took it off
