Results 1 to 2 of 2
Thread: 1983 200E Clutch Problem
    Oct 2005
    Huron County,Ontario
    20
    Question 1983 200E Clutch Problem
    I just put all new clutch parts in my 1983 200E Big Red. I bought a manual and followed the instructions perfectly and now i can drive it with the shifter down and if I start off in 1st with out at least 1/8 throttle it stalls, theres no pause between shifts it is really jumpy, it doesnt matter how i adjust it , Hard to down shift for 5-4 and 2-1-neutral. (I rebuilt the top end and replaced the 2nd gear. everthing worked fine untill I replaced the clutches 6 months later) I really need help so I can fix it instead of throwing away over $1300 in parts. Thanks
    1983 Honda ATC200E Big Red (Converted to Quad) "SPARKY"
    1982 Honda ATC200E Big Red (Parts Machine)
    Cheetah Mini Bike 4.0hp Honda (52 km/h)
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    If your problems truly started after the clutch install, I would have to guess that something in the assembly process didn't quite go right. Based on what you have said here, logic says there aren't too many other options.
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
