Results 1 to 2 of 2
Thread: 250r help please
    Feb 2006
    Rochester NY
    137
    Question 250r help please
    I took the top end of to change the base and head gasket and now I can't seem to get the cylinder to go over the rings so its not crooked! I can get it over the top one then it just wants to go on crooked and it seems like if one of the parts of the frame wasn't there it would go on straight!? Is there some kind of tip or trick somone can tell me to get this thing back together before I brake something! Its just weird to me Iv'e never had it go this hard before! Please help!!! Thanks in advance
    85 200x-sold
    82 185s
    85 250r
    92 cr500R
    94 Arctic Cat Thundercat 900
    Aug 2002
    New York
    1,098
    If it came off that way, it will go on that way.
    All I can say is make sure that you are at the bottom of the stroke with the piston and it should fit in between the frame rail and the piston. Take your time, get someone to help you guide the cylinder and make sure that the rings are lined up with pins on the pistion and it should go on fairly easy.
    I can't say any more. There really isn't a trick to it.
