Results 1 to 2 of 2
Thread: carb adjustment help
    Indiana
    115
    I have a 79 110 that i just got running again. Now it runs, and has plenty of power, but backfires like crazy, and is really rich. I put in a brand new plug, and after a minute of riding, it is completely black with carbon/oil. how should I go about correcting this?
    Also, what, other than timing, could be causing all the backfires? Thanks
    Gunnar is offline At The Back Of The Pack Arm chair racerFirst time rider
    Rose City
    181
    Any one of a thousand little things can cause it to be rich. And thats probably whats making it back fire. First check the carb afr screw may be out too far, too big of jets, bad needle, stuck choke. Check the carb first and see if its in good order then go from there.
