Thread: 350x spongy front brakes
    Jan 2005
    RI
    2,530
    When i replaced my front brake line and pads on my 350x the lever was perfectly firm. When i was riding, i squeezed it and it got soft, but firms up after a few pulls. I tried bleeding the brakes all day yesterday to no avail.
    When i pull the handle in, fluid squirts out of the resevior. Is this right? I already ordered a master cylinder rebuild kit off of ebay just incase so i can still go riding in PA next weekend.
    How do you rebuild a master cylinder?
    I searched on here but really didnt find any answers.
    Any help would be appreciated.
    Thanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    Great Bend
    704
    so far every ATC master cylinder I have re built are pretty much the same.
    once it is off of the handle bars and the lever is off look at the piston contact point. you will notice a rubber boot around it, take a pair of needle nose pliers and pull on it gently until it comes off. if new one is sent with the rebuild kit then it doesnt matter, give'r hell.
    once that is out of the way you will notice a snap ring. long thin snap ring pliers will make this part amazingly simple. if you dont have access to snap ring pliers, ice picks work but it takes 2 people to do it. one to hold the ice picks and pull the ring in and the other to lift up on the piston to get it out. same thing with the ring pliers, once the ring is compressed you should be able to lift up on the piston and get it and the ring out at the same time.
    watch out for the return spring and dont loose it.
    now once all the is done clean it until you are blue in the face, go drink a beer and then clean it again. when you are ready to go back together coat the new piston and the cylinder with brake fluid so everything will slide together smoothly. put the snap ring in. slide the rubber boot over the piston and make sure it is secured in its position. put the rezzy back on, put it on the handle bars, bleed the system and you are done.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Jan 2005
    RI
    2,530
    ok cool, doesnt seem too hard. I already have a rebuild kit coming, so i dont have to clean that much, just the rezzy.
    THanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2006
    Crestview, Florida
    2,429
    As for the sponginess feeling try using dot 4 fluid. Also could be the brake line is to soft.Was it a new or used line?
    Jan 2005
    RI
    2,530
    the brake line is a stainless line
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
