My neighbor got pissed at the kids for riding the 3 wheeler to much and decided to dump my tank full of sand. Whats the best way to flush the fuel system.
With about three quarts of your neighbors blood.
Good Awnser.............Or take the tank off and repetedly flush with gas, and then install a little inline fuel filtre, you will also have to take the carb off and give it a good cleaning compressed air.Originally Posted by Dammit!
1985 Tri-Z-
Originally Posted by mywifeknowseverything
Absolutely agreed!!!!!!!!
Remove the tank----Fill it with kerosene, cap it, slush it around, and then gently rotate the tank so the filler is facing down, and dump it, .. It may take two or three tries . If you have a fuel pump, I would replace it. REbuild the carb and you will be fine......The hard part wil be "Telling" (NOT ASKING) this inconsiderate PR**K to pay for it.
Buy American! Unless your only option is a HARLEY.
A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
You'll most likely never get every bit out, so install a good inline filter to catch those last hold outs.
just make sure you empty your tank in his yard!!
2 125 yamaha tri motos
1 yt175
1991 blaster
Prefrable on a Very Green chunk of grass......Originally Posted by holmstrom
1985 Tri-Z-
that will be brown after you light the gas!!!
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
I wouldnt let him get away with this.
2000 Rm250
1985 IT200
2003 suzuki sv1000s
2008 polaris outlaw 525s
If you have a good petcock valve no sand should be in the carb. You'll have to remove the petcock and take it apart to get it good and clean. You can flush the tank alot easier with it off also.
Originally Posted by mark38090
make sure you get his car/truck with some cement.
MY FEEDBACK---
http://www.pbnation.com/showthread.p...2#post20992142
+6 positive feedback.
WaLLa BinG WaLLa BoOm ShE's DoNe!!!
MY 225 Dx
Piped, jetted, 2 stage uni, wheel spacers.
__________________________________
My 82 250R
All original even with tool kit.
Stage 2 uni, no air box jetted.
Nooo!!! That would be lame. Make sure you empty it right back into his car's gas tank. Payback is a b...Originally Posted by holmstrom
well, I cleaned it all out and put it back together and it seems fine. i rode about 10 miles today and other than a running a little rough at low speeds, it runs great again.
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
I can't believe someone would have the nerve/guts to do that. That's horrible.
I put sugar in my x girlfriends gas tank that works really well!!!!
