I've heard this is a much better coil for the Z. I've been told that it will bolt right up and produce a much better spark. Anyone else here off this? What year Grizzly do I need?
Tri-z doesnt have a recoil..
2000 Rm250
1985 IT200
2003 suzuki sv1000s
2008 polaris outlaw 525s
ignition coil
WTF?Originally Posted by Rm250RF900R
I've read that to. Do a search, I'm sure you can find it.
Originally Posted by jsimonh
thats funny!!
the coil is one of thoes parts that is used on many differnt machines. i have not heard that a grizzly coil will work, it verry well could be possible.
Contact 03 Orange shee (Nathan) I know he did it.
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
Originally Posted by yzboyx
I hope you aren't addressing the better spark comment here. Contrary to what a lot of people think, hotter plugs do not produce a hotter, better, longer, or stronger spark. The term "hot" has to do with the heat rejection properties of the ceramic insulator. The hotter the plug, the hotter the insulator stays. The spark remains the same regardless of the heat range.why dont you just run a hotter plug?
Back on topic, I don't see why a Grizzly coil wouldn't work. As long as the wiring is the same between the two, it should work because the coil doesn't care if it's a two or four stroke, just as long as it gets an impulse from the stator.
Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
"To err is human, to err continuously is liberal." - Me
Im using a Warrior coil on mine too. Theres some information about the grizzly coil on a Z here
http://bigborequads.com/smf2/index.php?topic=84.0
85 Tri-Z "Rumble Bee"
85 250R "Red Rocket"
83 200X "Flat Tracker"
Wow what the heck was I thinking, he said coil not recoil![]()
2000 Rm250
1985 IT200
2003 suzuki sv1000s
Thanks for the info guys! I think I'm gonna order one off ebay. I read in a post that orange shee's was from a 98 grizzly. Thanks again!
