Thread: ESR kits...
    Aug 2004
    Ab Canada
    4,368
    ESR kits...
    Hey folks,
    Was just wondring if anyone here has or have run a ESR380 bigbore on the ATC or any 250 for that matter, and whats the clamined numbers on this? i have heard 80hp at the Crank..........Anyone confirm that?
    1985 Tri-Z-
    3leggeddog's Avatar
    Nov 2004
    i have not heard 80 horse for the esr 380,however PSI makes a 425 that is supposed to be the baddest.that one is claimed at 85 horse,and 70 # tourqe
    Aug 2002
    New York
    1,098
    The PSI won't fit in the ATC frame without modification. The motor and head aret too tall.
    Jun 2003
    englishtown NJ
    2,676
    you will have problems fitting a bigger bore than a 350 in a atc250r frame and most cylinder heads, the spark plug is in the center and straight up requiring you to cut and move the diagonal frame support. I have a lrd 310 pv and it has more power than most can use. I also have the correct pipe, igntion, carb and some other mods too.
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by 3leggeddog
    Yea i have Riddin the PSI....425 in a TRX...Frickin Hauls pretty good, I was lookin into the ESR kits for a Supermoto Bike i was thinkin of building.......Thanks!
    1985 Tri-Z-
