Results 1 to 3 of 3
Thread: 85 HONDA ATC 110 wont idle
    Apr 2006
    Columbiana, Alabama, United States
    19
    just putting my atc back together and it will start first pull only with throttle wide open. i removed air cleaner and it runs alot better but the only way it idles is to remove the air adjustment screw. with that out it runs great, with good throttle response. PLEASE HELP.
    Apr 2006
    Crestview, Florida
    2,429
    you have a pasage clogged in you carb somewhere . possible air leak between the carb and head.
    Apr 2006
    19
    thanks for the reply, i think i need to soak that carb and blow it out.
