Thread: big red becoming a problem
    Mar 2003
    Australia
    1,919
    hi
    my big red is really starting to give me the sh*&^ as i strip it down there is another problem opposing me every corner i turn, the latest one is on the rear diff, i got one side of the cover off but the Ba$@#^# who owned it welded the hubs onto the axel so i cant get the covers off to clean it out and the other cover wont come off, it is the side where the brakes connect too. is there a trick to getting it off or what????? i brought this triek for 900 australian and im starting to think the bloke ripped me off i reken its worth 500, its like it has been riden through SALT water and not been wahsed off afterward has anyone had any experiences with salt rust coverd bikes if so what did you do?????
    thanks
    matt
    Tweeked is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I have a 200es and the day I got it said "i'm not taking this one appart"...The thing is a tank and all the bolts and stuff are in akward places. I've never taken the rear gear case off so I wouldn't know but, why the hell would someone WELD the thing together? That makes no sense. Anyways, good luck...Salt water is a killer for any type of machinery...You gotta clean it off after riding if it has any salt on it.
    :Beerchug
    highly modded yfs
    Wine em', Dine em', 69 em'
    I'm a Bomb Technician
    If you see me running
    Try to keep up
    als250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Quote Originally Posted by Tweeked
    My guess would be, splines in hub or on axle (or both), were stripped! Quick fix: weld it up and go! You should be able to take grinder/cutoff wheel to weld (if you plan on re-welding it later) or just cut axle (you'll have to replace hub(s?) and axle).
    Al
    TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
    '86 350x (latest addition)
    '85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
    '85 250sx(supertrap exhaust,chrome rims)
    '87 200x(restored)-'85 200x-'84 200x
    That can get exspencive...Tell us what you end up doin.
    :Beerchug
    highly modded yfs
    Try to keep up
    Mar 2003
    Australia
    1,919
    yeah well ive decided to part out my big red and sell it. its a piece of crap.how much do you reken id get for a 200m frame in neare new condition in australian dollars
    matt
