Results 1 to 12 of 12
Thread: trike went crazy
    florida
    2,328
    Angry trike went crazy
    i just completly re did my 200s and i started it up for da first time wirh new exaust kn air filter.....well i let it warm up while i pump up the tires...so next i get on it hold the brake pop it into gear all of a sudden it wheelies and revs uncontrolably across the yard and wrecks not much damage (it broke my old mint fenders tho) and im tryyin to find out what da hell happended any ideas
    Gaylord MI
    106
    I am not sure, but sucks that the fenders broke. It is the worst feeling when they do.
    florida
    2,328
    yea it is i plasti-welded them they still look like sh*t
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Sounds like stuck throttle.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    florida
    2,328
    nope i checked that it idled fine but revved by itself when put into gear
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    check your throttle slide thing, the part that goes into the carb and has the needle on it, make sure it is in the right way,
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    florida
    2,328
    ok dats checked its fine i looked in the throat it closed and opened but i said it idled fine then revved when shifted
    Sep 2003
    Brookville,PA
    1,408
    Do you have the throttle cable routed the right way? Sometimes if not routed the right way when you turn the front wheel, it will tighten up and seem like the throttle is sticking. Just a guess, from experience.
    florida
    2,328
    good thought i just ran it under the fuel tank
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    try this, with the engine off, turn the handlebars while looking into the rear of the carb, does the slide go up or down?
    I replaced the handle bars on a 110 once, didnt realize they were for something bigger, I started it and put it in gear. I turned the bars to go around the corner of my shed and it took off on a wheelie, it threw me to the ground and pushed the storm door on my shed inside of it. The lil 110 was completely inside the shed, standing up against the wall spinning the tires!!!! I will never again put Big Red handlebars on a 110, nope, never.
    travis712's Avatar
    travis712 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Maine
    157
    LOL at Dave, laughing with you ofcourse :P...
    Did you check your cable routing? Make sure the slider in the carb is going back all the way, not just the cable is returning.
    florida
    2,328
    yea thats possible cuz the bars were turned when i put it into gear
