My trike will not run
it will only run by push starting it and it will not pull start.
I also need the owners manual for a yamaha tri moto 125![]()
Maybe a case of low compression. Need more details like did it run good before, when was the last rebuild, got a compression tester?
It does turn over when you pull start it right? I figure this is what you mean, just want to clarify. If it isn't catching at all, take apart the pull start mechanism and look for flaws. Try finding an online manual, also.
do you think it could be the compression release valve?
Compression or ignition. Pull starting cranks it over faster than pull starting because of the transmission speed.
Yeah, push starting it will likely produce a more robust spark from the plug than using the pull start. Its fireing a lot more often and faster when you push crank it. Could be a weak coil or something with the ignition system.
Clay Whitman
Newnan, GA
AMSOIL DEALER
My Toys
2008 Yamaha Rhino 700 SE
Thanks you guys ill look into it more with a clymer manual and see if i can fix the ingnition problem
my 250X did this and it turns out it was the stator, just a thought, dont know if thats it on yours, but that was my probelm
what is the stator?
If this is tri moto 125 I had a 1981 that did this same thing and was low compression.
Trikes currently owned
E.T. trike 150H.P. and climbing Pure DRAG beast
85 250r project
what did you have to do to fix it?
does anyone know were to buy a piston for one of these bikes ?
www.ebay.com would probally be the cheapest or try www.denniskirk.com Good luck!
85 200x-sold![]()
82 185s
85 250r
92 cr500R![]()
94 Arctic Cat Thundercat 900![]()
try seller jkwaterparts on ebay.com great people to deal with and cheap.
Check compression before shelling out the "JING" on a new piston
Buy American! Unless your only option is a HARLEY.
A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
