Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Awww... crap. How to fix this?
    Phoenix, AZ.
    6,719
    NAPA didn't have the 3M bumper repair epoxy. They sent me to the auto body supplies place and the guy there recommended this PC7 junk.
    Where can you get the 3M stuff? Any major retailers carry it?
    If I don't have it fixed by thursday evening, the brand new black OEM tank is going on...
    May 2003
    Shediac, New Brunswick
    1,126
    Just use JB weld.. its crazy stuff.. It will work... Stop messing around
    '84 Honda 200x
    slow restro
    Phoenix, AZ.
    6,719
    I think I'm going to strip another one on the junk tank on purpose so I can test Old Faithful (JB Weld).
    May 2003
    1,126
    ha ha yeah..
    But really how would it not work? Say for some reason it doesnt stick to the plastic and only to the metal.. as long as you fill the hole.. it isnt going to spin anymore... probably solved... I am pretty sure it will stick to the plastic though . but incase it doesn't make sure you pack the jb in the hole good.
    '84 Honda 200x
    slow restro
    Jan 2005
    RI
    2,530
    get some marine tex...I used it to fix my headlight case on my 250r. I tacked all of the plastic together with some worthless super glue. then used the marine tex over all of the tacked spots, sanded it all smooth after it was dry, painted it and it looks great.
    Marine tex will bond to anything. The best part is that you can sand it afterwards if needed. I really think its the way to go. Its cheap at like 13 bucks for a good amount.
    Ive used it on the headlight shell, on my worn rear axle on my 200s to keep the hubs nice and tight, and to fix a pinhole in my pipe on my 250r. Its really great stuff.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Phoenix, AZ.
    6,719
    Quote Originally Posted by short4stuff
    ha ha yeah..
    Well, if it bonds to the metal and not the plastic, it's essentially just making that square metal piece into a round metal piece if you think about it. The hole in the tank that used to be square is more or less round now so there's nothing for it to catch on. I'd like to get it right on the first try because if whatever I use does not work, I'd have to get it all out before trying something else.
    Apr 2005
    Easton, MO
    142
    Just go to walmart and get you some plastic weld. It's a two part epoxy in a syringe. Located in hardware with the other epoxies and glues.
    Phoenix, AZ.
    6,719
    The PC7 and JB Weld failed miserably on the test tank.
    Jan 2005
    RI
    2,530
    seriously, try marine tex.
    Im positive itll work. If it can hold my headlight shell together like its brand new, it can hold that stupid little nut in there.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Theres a certain type of Loctite brand clear super glue, cant remember the name of it but check around. Tiny bottle is about $10, but it'll hold like 8-9k psi and it DOES stick to plastic. I know, I've used it before.
    moncton nb
    149
    I dont know about where your from but here There is JB plastic weld out..I used it tp hold to gether a hesd light bucket and then fliped the bike end over end and smashed the fromt fender but the bucket stayed pretty good
    HELLONWHEELS
    Anaheim
    1,270
    Doug use epoxy, its made for that, jb weld and PCHIT7 are out of there element... GOOD LUCK
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I would try a plastic welder. Pull the nut out of the hole, clean the hole up, then weld the nut back in.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Apr 2006
    Crestview, Florida
    2,429
    try a local body shop, they'll have the good bumper repair stuff.
  15. #30
    Phoenix, AZ.
    6,719
    Here's an idea. Screw that old tank!
    Out with the old. In with the new.
