Thread: BIG RED vs 250SX top speed?
    Dec 2003
    australia
    838
    I used to own an ATC250es or 250 "big red", They were called "super reds" in Australia and they never sold 250SX's over here.
    I was always curious as to the differences between a "big red" and a 250SX. If you look at a big red engine and drive line they are identical to the SX. IE: 250cc, shaft drive, electric start and reverse.
    Is the SX faster top speed? The big red has bigger tyres than the SX so that would lead me to think that the big red had a higher top speed. Did they change the internal gearing for the SX?
    Does the SX have a super low first gear like the "big red"?
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    Mar 2003
    Australia
    1,919
    There is a diffrence in the gearing somewhere. Im pretty sure it is the diff gearing but I have never been able to get a straight answer. The 250sx has a higher top speed than the bigred. I find my 250es does lack in top end a little bit...
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Bartlett TN
    3,083
    Yes the SX has slightly different gearing from the big red. It doesnt have the super low gear like the big red, but has a much faster top gear. I like the big red much better when climbing hills and such as the low is nice. With the SX, you have to play with it to get the right gear to make it up hills, or you have to hit it hard.
    86-87 Tecate ROCK!
    Dec 2003
    australia
    838
    I feel your pain matt, great for workin on but needs another gear when your playing around.
    Have you thought of buying a sport trike yet?
    I see a very nice Tri-Z is advertised from Brisbane at the moment
