throttle circuit/cable
frist off i wanna thank yall for puting yup with my none spelling ass... ok got it to get gass but the throttle still a little funny is like sticky is the best way i can think to put it abd the book i have does not show any way to fix it any help would be real nice thanks
if its a well used cable it will be way easier to spend the 12 dollars and buy a new cable and save yourself a headache.
if its a new cable look for kinks and sharp bends. if it has been bent then it is never gonna work right again, even when straightened it will always catch were it was bent.
1985 KXT 250
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
All I can think of is go to your nearest motorbike dealer where you can get a block to clamp on to your cables it has holes in it just big enough for the straw from a wd40 can in it attatch and squert . Then while you have the top of the carb off with a cleam rag wipe around the top. hope this helps a littel
Log dog
1 Wife
3 Kids
Honda big red
Honda 400/4
try cleaning the slide in the carb with fine sand paper
//ArrowChat Integreation Code
