Results 1 to 3 of 3
Thread: 250sx reverse light not working
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    The reverse light on my 250sx is not working and I check all the wires around the frame and nothing was broke or corroded. What could it be?
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    Pa.'s Highest City
    8,058
    Easy fix. Under the right side of the motor by the footpeg there is a small guard. take that guard off and the neutral and reverse plugs are there. Make sure they are cleaned up real well and there is no dirt in the connections. I just did this a few short weeks ago and both my lights work fine. If it's not that check the bulb or their connections.
    crd00's Avatar
    Feb 2006
    323
    Thank you so much, thats the answer I was looking for because the same thing happened with my 200m except it was the neutral light because it has no reverse and I had to sauder the wire back on, I knew it was something along those lines
