Results 1 to 15 of 23
Thread: HUBS to RIMS and AXLES DATA BASE
    Dec 2003
    australia
    838
    As parts for our machines become scarce and swapping parts between models might save a machine. I think we should make a Hubs to Rims, and axles Data base.
    Hub bolt patterns for example:
    86/87 Tecate rear hubs are a 156mm x 4 bolt pattern
    TRI-Z/banshee*/Raptor/YFZ450 rear Hubs are 115mm x 4
    *89/90 banshee are 156mm x 4
    83/84 250R hubs are ???mm x 4
    85/86 250R hubs are ???mm x 4
    84/85 Tecate hubs are ???mm x 4
    83/84 200x hubs are ???mm x 4
    You get the picture. Can anyone fill in some blanks?
    From what I can gather the main 4 bolt hub patterns are
    100mm x 4 (early honda?)
    110mm x 4 (later honda?)
    115mm x 4 (Most Yamaha stuff)
    156mm x 4 (Kawasaki racers?)
    Am I close?
    Next, Hub to axle combinations. I can fit YFZ (Quad) hubs onto a 86/87 Tecate axle. Slightly loose but firm up nicely with a packing spacer and axle nut. But I can't fit 86/87 Tecate Hubs onto a YFZ axle.
    What other Hub to axle combinations are viable????? (I don't mean smashing them on or "creating" extra splines......... (you know who you are), and
    Lastly, Axle to machine combinations. What axles are interchangeable. For example; Apparently you can fit an 86/87 Tecate axle into an 84/85 Tecate?
    There must be a wealth of knowledge our there Boys
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    bigb9582's Avatar
    bigb9582 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2005
    pa
    167
    02 blaster hubs will fit a 85 tri-z, 8? yamaha 200.
    82 honda 200 hubs will fit a 86 200s.
    they all have diff bolt patterns. not sure what they are tho.
    85 atc250sx
    86 lt230s
    85-86 tri z are 4-100 all blasters are 4-100 too
    raptor-yfz-banshee-warrior are all 4-115 and will all fit on a 85-86 tri z axel
    Sep 2005
    MICHIGAN
    2,027
    Spline count would be nice too. 84 KXT250A is 4/100 (13 spline). All KAwasaki Mojave and Polaris Predator are 4/156. T3 KXT250B are 24 spline like 200X and Yamahas (but do they fit?).
    86 T3
    84 T3
    86 KX250
    travis712's Avatar
    travis712 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Maine
    157
    Its also 83-85 for the 200x, not 83-84.
    86 200x- finally all back together
    Newfoundland
    5,280
    200 X hubs fit the 2nd gen Tecate.
    Dec 2003
    australia
    838
    OK so this what I have so far;
    HUB stud pattern (# of splines x diameter of splined section) = Applicable Models
    4 x 100mm (24 x ?mm) = 85/6 Tri-Z, All Blasters, YTM200
    4 x 100mm (13 x ?mm) = 84 Tecate
    4 x 115 (24 x 25mm) = All Raptor, YFZ, Banshee*, and Warrior
    4 x 156 (24 x 24.5mm) = 86/7 Tecate, Predator, Mojave, 89/90 Banshee*
    4 x ??? (24 x ?mm) = Years? 200x/s/m
    Is correct?
    What about you honda guys? Speak up or forever hold your piece.....
    I'll keep modifing this information as more people post on this thread
    Apr 2006
    Bronco Country
    64
    If anyone has any clue as to what other rear axles will fit a 1984 Honda 200M, that would be greatly appreciated. I'm looking to buy one, but not sure what else will fit it.
    Thanks.
    Go Broncos!
    BTW, 1984 Honda 200M
    Jun 2004
    Pyeongtaek, South Korea
    474
    The only hub interchange that I know of is 250X/300EX/400EX/450R hubs will swap right onto an 83-85 200X axle. Those hubs will also get you about two inches of extra width over the stock parts.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Dec 2003
    australia
    838
    Does that mean then:
    4 x ???mm (24 x ???mm) = 250x, 300ex, 400ex, 450r, 83/4 200x
    Gents What i'm asking is WHAt IS THE HONDA stud spacing 4 x 100? 4 x 110?
    Nov 2004
    Mass.
    90
    Hubs
    86 200x hubs will fit on a 96 Blaster didn’t believe my son till he showed me.
    Sep 2005
    MICHIGAN
    2,027
    So if 200x hubs fit Tecate B1/B2 and 200x hubs fit Blaster then Blaster hubs fit Tecate. I made a thread about this and got no answers so now I am just gonna have to buy some Blaster hubs and find out myself.
    86 T3
    84 T3
    86 KX250
    Dec 2003
    australia
    838
    OK This list is growing, this what I have now:
    HUB stud pattern (# of splines x diameter of splined section on the axle) = Models
    4 x 100mm (24 x 25mm) = 85/6 Tri-Z, All Blasters, YTM200
    4 x 110 (24 x ?mm) = 83/5 200x/s/m, 250x, 300ex, 400ex, 450r
    Is correct?
    I need the Diameter of the honda and 84/5 tecate, splined sections.
    Also a conformation of the diameter of the Mojave/Pred splined sections.
    Blaster hubs will fit an 86/87 Tecate but will be a bit loose. Look at the chart above
    Bartlett TN
    3,083
    Here is a nice chart that I have posted many times for honda bolt patterns.
    86-87 Tecate ROCK!
    Dec 2003
    australia
    838
    Great chart, We need a chart like that for all the models.
    It needs a bit extra info though, Like how many splines on the hub ends of the axle. Additionally the diameter of the splined sections.
    Was this and OLD 3wheeling article?
