Thread: help with 125m/ trx125 ring replacement
    Dec 2002
    deer park, texas
    2,336
    i just acquired a 125m with a 1985 trx125 motor in it. the motors look to be the same. Well anyway, the motor was locked so i let the top end soak overnight and today after fiddling with it for a little while i got it to break loose. to my astonishment this thing cranked up with a little starting fluid to get it going. i ran it for about 3 minutes and it died. i then could not get it to start back up. i had spark, had fuel then i was noticing oil seeping from the dipstick. when i turn it over i have tons of compression and oil comming out of the the dipstick hole so i must have broke a ring. now here is the question, how do you remove one of these top ends. i have never pulled one off before and i am kinda confused how to get the timing chain off. can someone please help?
    Dec 2002
    deer park, texas
    2,336
    come on, i know there is someone who knows how to pull a head on a horizontal style honda motor in here
    Dec 2002
    deer park, texas
    2,336
    i am down to the timing chain, How in the world do you get this thing off!!!!!! i am in dire need of help. i hope i dont have to pull off the side cover and remove it from the lower end. PLEASE HELP!!!!!!!
    Dec 2002
    deer park, texas
    2,336
    i figured it out and got it apart. the ring inst broke though. i am going to look into it tomorrow and see what it might be.
    kando is offline At The Back Of The Pack Arm chair racerFirst time rider
    Saskatchewan
    212
    I would say your float is sticking in carburetor and gas ran through cylinder pushing oil out thruogh dipstick. Just clean carb and you will be good to go.
    1982 YT 125 Yamaha 1984 Honda 200 m
    Dec 2002
    deer park, texas
    2,336
    i am having compression in the lower end .
