Results 1 to 12 of 12
Thread: where there is smoke
    Springfield OR
    17
    i noticed a problem last time i had my 200x out. after it warmed up i noticed it was smoking fromt he tail pipe. Now being a car guy i know blue smoke meand oil. but the weird problem is it smokes when warm, not cold. i have been storing it on the back wheels but i thought that will be ok. been told it could be cheap oil. i guess what i am confused by is the spark plug showes no sign of oil fouling. could it be oil leaking into the tail pipe due to the way it is stored or should i look for a rebuild kit? and while i have your attention who sells the best (also inexpensive) rebuilld kit for a 1985 200x. ooh and how difficult is rebuilding one of these little critters?
    Springfield OR
    17
    anyone have an opionion?
    Randolph NY
    597
    Check your airbox for water and your headpipe bolts making sure they are tight. Im going to guess its water in your airbox or a dirty carb check your airbox first then tear down your carb and give it a good cleaning.
    Apr 2006
    Crestview, Florida
    2,429
    try running 20w50 oil
    Springfield OR
    17
    would a dirty carb cause smoke? wouldn't it alsp flood or backfire once and a while? judging by the color of the smoke i would say it would have to be oil, but my plug is not oil fouling. if anthing the plug is getting carbon fouled.
    and as far as 20w50 i thought the way multi grade oil worked was as the engine got warmer the oil got thinner. do i have it backwards? Also i thought i read on a recent post multigrade oil was bad for trikes?
    Randolph NY
    597
    I use multigrade in everything with my trikes. The 350X runs better with it! I would say clean your carb and check your airbox for water. If its white its either water/condensation or your carb is dirty.
    Apr 2006
    Crestview, Florida
    2,429
    if you are storing it on the rear wheels? that could be your problem. oil is running back in the carb. does it clear up after a long ride?
    Springfield OR
    17
    haven't given it a long ride yet will do so this weekend, how long before it should clear up an hour or two?
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Quote Originally Posted by Erics350x
    20/50? That's too thick!
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Springfield OR
    17
    20/50 is too thick? what would you suggest
    springville, PA
    6,185
    how about 10w30. 20 is way too thick
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Randolph NY
    597
    Or 15/40. Take your carb off and give it a good cleaning. They are pretty self explanitory and easy to dissasemble and reasemble if you pay attention to how they come appart.
