Results 1 to 7 of 7
Thread: 200X Fork Boots with pics ??????
    Apr 2005
    Blue Ridge Mtns NC
    59
    Question 200X Fork Boots with pics ??????
    Hi all, I have attached an e-bay link showing a pair of 200X forks which are identical to mine. Notice the rubber dust seal between the upper and lower sections. I posted a thread a week or so ago asking how the fork boots are supposed to fit over this dust seal? I see other forks that have an internal dust seal that the fork boot covers. There is a clear difference.
    Do I have the wrong year shock on my 85 200X, or did service honda send me the wrong fork boots? Again the attached link shows the identical forks that are on my trike.
    http://cgi.ebay.com/ebaymotors/FORKS...34816417QQrdZ1
    Jan 2005
    Great Bend
    704
    those are fork gators. they act as a secondary swiper and seal. you take them off and slide your boots on over the slider for a factory look.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Apr 2005
    Blue Ridge Mtns NC
    59
    fork gators huh?
    So is the fork gator an orginal honda installed part, or is this an aftermarketr piece someone else installed? Also When I remove the fork gators, I can see down into the fork where the circlip is. Is this normal or am I missing the "internal" dust seal. You mentioned that the gator is a secondary swiper?
    Jan 2005
    Great Bend
    704
    yea if you look at a schematic picture of the forks you will notice in order the seal, circlip(snap ring), and then the swiper, then the aftermarket gator seal goes over the OEM swiper, gators are not a factory piece. your manual has an exploded view of the fork or www.bikebandit.com has one as well.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Apr 2005
    Blue Ridge Mtns NC
    59
    skematic interpretation
    Is part #13 the gator seal? I thought there was some sort of seal that installed inside the fork over top of the circlip area. In fact I just ordered a set of seals from service honda. But it looks like I ordered another set of gator seals if these are part #13?
    When I remove the gator seals from my forks it simply looks like the circlip area is too exposed to moisture and dirt using only a fork boot. (Fork boots snap in place but are not to water tight) I wanted to buy replacement seals that fit inside the lower fork so I can slip the new boots over the lower shock and have it fit like original.
    May 2003
    Shediac, New Brunswick
    1,126
    I think what you need is the dust seal.. look at this auction .. thats what a normal dust seal looks like.. http://cgi.ebay.com/ebaymotors/1985-...spagenameZWDVW see the black piece.. thats what your missing right?
    '84 Honda 200x
    slow restro
    Apr 2005
    Blue Ridge Mtns NC
    59
    Yes that is exactly what I need. Hopefully this is part #13 from the Bike Bandit skematic linked above. The Honda part number I ordered was 51425-473-003. Hopefully this is the correct part number for these dust seals.
    Where does a person purchase the gator seals? It sounds like they are aftermarket.
