Results 1 to 7 of 7
Thread: gas in AIRBOX please help?????
    Feb 2006
    Jefferson City, Missouri, United States
    63
    Unhappy gas in AIRBOX please help?????
    In the 125m I just got, I figured out why it dosen't stay running, Instead of the gas going and stayong in the carb it just runs into the air filter box. What is worng? I'm not sure. please any help would be great. Thanks for your time.
    -C.J.-
    Jan 2005
    RI
    2,530
    sounds like your float needle is sticking open and filling the bowl and its drainign into the airbox and probably the cylinder then down to the bottom end
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Feb 2006
    63
    what would I have to do to fix it. Should I buy a rebuild kit or what?
    Apr 2006
    Crestview, Florida
    2,429
    could just be trash in the float valve seat. if not replace it and possible the float.
    Jan 2005
    RI
    2,530
    carb rebuild kits are cheap.
    look on ebay, mfgsupply.com or hyperparts.com they should all have them
    they will be like 15+ shipping...cheap in my opinion and worth the piece of mind that the carb is good to go..
    you would also want to clean the air filter and reoil it, and probably drain the oil in the motor and make sure that there is no gas in it. Then refill it an dyou should be all set
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Feb 2006
    63
    thanks for your help guys
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    yeah, i would first take it off, tear it apart (really simple) clean it, put it on and adjust it as needed. See how that works.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
