I'm putting my auto-x back together and trying to put the sprocket back onto the cam. The sprocket can go on two ways.....do I want the lobes pointing up or down while putting the little O on top?
Cam lobes Down, and O on the bottm i belive,,,,
1985 Tri-Z-
Originally Posted by mywifeknowseverything
My manual says O at the top, but says nothing about position of the cam?
Could be O on top....i havent done one in a while, But im postive cam lobes down, cause you have to set the motor at TDC pop the cam in, lobes down so the valves are Closed......then Set the cam chain on.......ect...
1985 Tri-Z-
Cam lobes down, when putting pulser coil on line up the timing marks to the pulser coil flywheel
