Results 1 to 10 of 10
Thread: newbie performance questions
    Apr 2006
    Yuma, Az
    109
    I just bought an 86 250r atc all stock. I know I need a pipe and silencer but what else should I do to it on a budget to make this thing screem? I don't want to be beat by any of my boys and thier 4 stroke quads. And where is the best place to get these parts..... Thanks for the help...
    Apr 2006
    PA
    1,464
    filter, jet it, raise gearing (one up in front and a smaller rear 14/38-39?, maybe a port and polish. Once you raise the gearing on thoes they fly.
    Sep 2005
    wisconsin
    475
    yea id for sure change the gearing
    atcsteve's Avatar
    atcsteve is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    arizona
    157
    The pipe will be your first real HP gain,then you start giving it more fuel,like good reeds,bigger carb,good filter ect...Gearing is also a good idea.I would just drop the front sprocket i tooth,and run good fuel & oil. Hope that helps!
    85 250r drag bike
    87 trx 250r ESR big bore
    Newfoundland
    5,280
    Question is where do you want to go fast? An all out speed race or just a short drag?
    Cheap way to go is milling the head for more compression, new reeds and a pipe/rejet.
    Apr 2006
    ghettosburg
    43
    Quote Originally Posted by BigGreenMachine
    What's a good amount to mill? That would be like shaving the entire flat part of the head right? I ask because I'm pretty new to this whole area of 3-wheelers.
    Aug 2005
    Portland Or
    412
    Assuming it runs well as it is: pipe it, K&N, boysen reeds, jet it, and down a tooth on the front. then see if you want to jump into all this head work, especially if yer new to all this. These are just the basics that should only see ya back 600 or 700 bucks. Look online for cheap suppliers. Rocky mountain atv has sprockets for like 8 bucks. If that isnt fast enough for ya then tear er apart and go to town. port and polish, carb, 310 kit....arrg arrg arrgg
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Apr 2006
    Yuma, Az
    109
    where is the best place to get aftermarket parts for a 250r.
    atcsteve's Avatar
    Jun 2004
    arizona
    157
    Shop the ads on this site,lots of good deals.
    85 250r drag bike
    Feb 2005
    Canada
    663
    denniskirk.com is also a good online place to shop.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
