Results 1 to 8 of 8
Thread: help!!!!
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    help!!!!
    i have a 350x. when i try to kick it goes down ral easy and then pops back up real hard.i already messed up my ankel trying to start the SOB. also my sprocket shaft moves in and out a little bit. is this normal? thanks for any help.
    Apr 2006
    Crestview, Florida
    2,429
    a small amount of play in the shaft is normal. as for the kickback check the decompression cable while moving the kicker to see if its functioning. the occasional kickback is normal. hurts like hell. helps if you kick the first 1/4 of the kick slow.
    uniontown pa
    472
    i put a new stator and case on it and that is when it started doing that. when it started up it missed lioke crazy. then after about an hour of looking at it i realized a couple of the wires were on wrong. i switched them maround and it runs fine and does not f up my leg anymore. as for the shaft every time i pop out my clutch my chain pops off on the front sprocket. what should i do?
    3leggeddog's Avatar
    Nov 2004
    if it has that much play in the counter shaft something is wrong.what does it do if you let out the clutch easy?is you chain tightned properly?
    sound like maybe a clip,or something has let loose inside allowing the shaft to move that much.never heard of such a thing.
    uniontown pa
    472
    the chain is tight and it will go when i go easy on it but when i let er eat it pops off every time. the shaft just started moving about a week ago. i had sombody put a new one about 3 moths ago. ran fine then. what is inside to make it move like that. i have all the parts if i need to replace it also. i have a whiole other motor stripped down . so let me know.
    Apr 2006
    Crestview, Florida
    2,429
    theres a circle clip on the counter shaft that holds all the gears in place. it prolly wasnt clipped in all the way. or some one left out a washer somewhere. pull up the diagram on servicehonda.com/hard%20parts/hard_parts.htm
    Richland WA
    808
    Look at the rear carrier and axle too. The chain tension has to be right when the rear wheels are off the ground, and when the rear frame is squashed down too. Have someone else (or two someone elses) sit on the seat and see if the chain is loose then. Hitting teh gas hard makes the rear end squat down and that might be when it comes loose.
    uniontown pa
    472
    ill try that before i go into the motor. i already put like 1200 bucks in fixin it up though. i hope that works!
