Thread: 250SX Speedo kit work on a 350X
    Antioch,California
    149
    Will a 250SX Speedo kit (08175-HA600) work on a 350X ???
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Yes. Any right hand mount kit will work. The gear may be slightly off in calibration. Slightly. May be dead on. But it will work for sure.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    wales..uk
    1,318
    Yep it will work but the cable might be to short....
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    True dat, the cable is too short and the bracket holes probably will not line up, they didn't on my 250R. I drilled another hole in the bracket on top of the first one and used both pinch bolts on the triple to mount the bracket. I also used the speedo cable from a XR250 or XR400, it was a tad long but worked fine.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Bartlett TN
    3,083
    You can use a cable from the CB350 street bike as its pretty much perfect length for this application. Its alittle long for the big red/SX but works both ways.
    86-87 Tecate ROCK!
