Results 1 to 15 of 17
Thread: Need Some Polaris Scrambler Help
    Newfoundland
    5,280
    Got a buddy with a 2x4 Scrammy 400. He is in the middle of installing a new AAEN pipe and clutch kit but has hit a snag.
    The middle bolt on the clutch won't budge. He is trying to install new springs and the center bolt won't budge. Anyone know if the bolt is opposite thread or Loc-tited in? Any help would be appreciated.
    James
    Newfoundland
    5,280
    That worked great for me. Forwarded it on to my budd and hopefully he can use that as a reference. Waiting for the 400 Scrammy expert to get back to me with answers too.
    Thanks Jes!
    NE Arkansas
    2,344
    My friend did that to my Scrambler after he bought it from me. I could not believe how strong that thing was after the pipe and clutch spring. BIG DIFFERENCE!!!!
    My Rags
    Washingtons Crossing, Pa.
    2,977
    Which clutch is he having trouble with - the Primary or the Secondary?.
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    your having trouble taking the primary clutch are ya?I just had to take the primary clutch off of my Cyclone, it says you need a special Polaris tool, i know a way you can get it off will tool around the garadge, if you wanna know how just say so. Unless you already got it off,
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    the aaen pipe does make some power, if he hasn;t replaced the piston with a wiseco he needs to with the increased rpm of the pipe he's setting himself up for a time bomb.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Newfoundland
    5,280
    Believe its the secondary.
    Nov 2004
    Mass.
    90
    Quote Originally Posted by 85hondaatc125m
    If he dosen't (I do) Can't get the one on my 250 off. Didn't mean to jump on his thread
    Parts for sale
    85 KX250 Roller with engine
    KDX motor
    2004 E-Ton Viper 50 Needs work
    Honda 87 Fat Cat Roller
    Honda 200m motor
    Honda 110. 80 frame 82 motor For parts. Runs.
    Honda 84 ATC 70 Roller Cheap.
    XR75 complete bike
    XR80 parts
    Yamaha 225dx parts.
    Honda 84 200es parts Good bottom end. (quad conversion front end)
    Kawasaki 93 KX80 Motor (needs piston & bore)
    Yamaha 88 YZ125 cases
    Suzuki 85-87 LT230s 2 complete parts bikes.
    Honda 83-85 200x Parts
    Honda 86-87 200x Parts
    Aug 2004
    tallahassee FL
    392
    get a piece of 3/4inch fine thread all thread from the local hardware store and two nuts to fit. jam the two nuts together or weld them on at one end.
    insert a 3inch 3/8 socket extension into the hole for the primary clutch and then tighten down the all thread. the socket extension will push in the crank and seperate the primary clutch from its taper.
    you can also use a 3/4inch fine thread trailer ball.
    Aug 2004
    tallahassee FL
    392
    you shoudn;t have to pull the clutch to replace the spring just get the center one loose and remove the 6 outer bolts.
    Sep 2005
    769
    Quote Originally Posted by conig
    I did the same just didnt use the nuts, put the 3 inch extention in the clutch 1st, get a fair size bolt, maybe 4-5 inches of thread that will fit in the clutch(like he said i think it is 3/4inch fine thread) start tightening with hand until you cant anymore, then get a wrench to fit the bolt and tighten it, and the clutch will just pop loose. Yea, i guess im 1 hour too late to reply to that, ill mention it know because I made this mistake, the part of the extension that connects to rachet, it goes in first, by the way. If you need anymore help just let me know, oh and conig, sounds like he knows his stuff too
    Current Rides
    Sep 2005
    769
    Quote Originally Posted by BigGreenMachine
    The secondary clutch should just pull right off, maybe spray it with some WD-40
    Current Rides
    Nov 2004
    Mass.
    90
    clutch
    Great, thanks guys I will try that tonight,
    Parts for sale
    KDX motor
    Honda 200m motor
    XR75 complete bike
    XR80 parts
    Yamaha 225dx parts.
    Newfoundland
    5,280
    He got it installed today, just a case of a stuborn bolt. All thats left to do is rejet. Anyone got base line jetting specs for this new pipe?
    2,977
    Is it the Trail pipe or the Top end?. What carb, stock 34mm?. If its the 34mm - stock main is #230. For the Top-end pipe, most guys end up with a 250/260 main - but - that depends on your altitude and temperature. With my 38mmTMX and the Top Ender, I run a 280 summer and a 290 winter.
