Results 1 to 13 of 13
Thread: can some one tell me how a thread file works
    Sep 2005
    FL
    855
    I messed up the threads on a couple of 350x cranks. Just the first couple of threads, so I can not get the bolt started. Some one told me to use a thread file, but I have never use or heard of one before. I appericate any help. Here is a link to what he told me to use. http://buy1.snapon.com/catalog/tools...e=snapon-store
    yes thats a thred file each side is a diffrent pitch, make shure you get the one with the pitch you need. use it just like a file and the teeth take off the curled over part then run a die down it.
    no its for a male end like the end of a crank or axel
    I use them alot for cleaning up badly peend threds so you can get the die started right..
    they been around for a long time..LOL
    Sep 2005
    FL
    855
    Oh I thougt it was for female threads too. So it will not work on female threads? The threads I am working on are female it is what the flywheel bolt goes in. If I use a tap how do I make sure I get it started right. I don't want to double cross the treads. I may still have to get a file if it will fix the front axle on my BR.
    sometimes if its not bad like a burr thats all you need, it works really well!
    its a tool that you must have in the shop.
    Sep 2005
    FL
    855
    Just for male threads though? I just want to make sure I get what it is for now. I appericate you help Bryan. Any ideas on the best way to repair female threads. I was trying to use a helicoil but I may have to.
    yes you will need to tap that this tool wont work on that,whoever must of thought you were talking about the male
    Sep 2005
    FL
    855
    Thanks again.
    start it as straight and level as you can they will usally follow the easeyst path!
    Sep 2005
    FL
    855
    Cool I will give it a shot tomorrow if I get time. If all else fails helicoil here I come.
    Dec 2002
    Kansas
    2,387
    Quote Originally Posted by dreadhed
    helicoils are for internal threads only unless I have never seen or heard of external heicoils
    thread files are easy to use
    I had the RIGHT to remain silent, I didn't have the ability!
    Sep 2005
    FL
    855
    Ya I know. That is what I am fixing female/internal threads. It is where the flywheel bolt goes into the crank. Although if I rember right I have heard of some sort of helicole for male threads, but I was wrong once & it may happen again. lol
