Am I doing something wrong? The chain on my 83R wont come any looser and it is rubbing on the lower frame rail. it has the stock number of sproket teeth front and rear and stock number of links in chain. I take the rear wheels off the ground, loosen the 2 bolts on the rear and turn the adjuster but nothing seems to happen, also how do i rotate the bearing carrier, i dont see the grooves to turn it, do you? Thanks
