tri- z info needed ?
i have just picked up a250 tri-z and had a few probs ,most are now sorted out.but i think its got the wrong type of plug in . NGKR BR8EG,Can anyone tell me if it should have a hotter plug than this and if so what ?
you have the right plug. The B8ES is what I have in mine. They are the same size and heat range, but yours has the resistor to help with interference and is a G series which is the racing type. I got all the info from here: http://www.concours.org/se/tech/ngk_plugs.html
85 200x - Torn apart
i need a manul for my 85 triz and i need some parts got any?
Thanks
Re: tri- z info needed ?
thanks to 200xer ,your a diamond :-D ,
//ArrowChat Integreation Code
