Can someone tell me how to adjust my clutch and valves? The clutch doesn't slip much just a little bit in third gear if i'm not rollin good. As far as the valves, they rattle some and seem to get worse after riding for a few hours.
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
Valve Adjustment
Take the valve covers off and line the "T" mark up with the notch. If both valve rocker arms have a little play in them then check there cleacence, if they don't both have play then spin the rotor over once (1 rotor rotation) = 1/2 a cam rotation) and line up the "T", now they should both have play. The clearence is intake = .05-.09 mm (.002-.004 in), exhaust = .11-.15 mm (.0043-.006 in). Now pull the engine over a few times and check again.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Clutch Adjustment
On the right side engine (clutch) cover there is a nut, loosen it. Then turn the screw that is on the inside of the nut Counterclockwise until slight resistance is felt. Now turn the screw clockwise 1/8 turn. Then while holding the screw in place tighten the nut.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
