Results 1 to 7 of 7
Thread: stripped fork lower bolt
    Feb 2006
    Wapakoneta,Ohio
    17
    ran into a problemreplacing the bent fork on the 200X
    wheel and forks came off easily
    did break a bolt on the lower tree just a matter of getting a replacment bolt
    replaced the left tube
    went to remove the bolt on the bottom of the right fork lower and the allen head bolt stripped the 6mm allen bit spun
    now how do I get the bolt out so I can remove the tube
    1985 Honda ATC200X
    1986 Honda TRX250
    5 CB750 Honda choppers
    1973 Mustang coupe
    1991 P71 Corwn Vic
    Jan 2005
    Great Bend
    704
    drill it out yourself or take it to a machine shop and have it done.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Feb 2006
    Wapakoneta,Ohio
    17
    I'll give that a shot drill off the head and bent tube should come out
    1985 Honda ATC200X
    1986 Honda TRX250
    1973 Mustang coupe
    1991 P71 Corwn Vic
    Jan 2005
    Great Bend
    704
    yea. drill it first with a 1/8" drill bit for a pilot hole and the use a bigger bit. be careful not to damage the slider when you are drilling that bolt out
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by 73coupe
    If you can't get it out or damage it, then stop on over. I have a bottom piece.
    Howdy
    CUYAHOGA FALLS, OHIO
    1,242
    What I Would Do
    I would drill it out. Tap it. And heli-coil it. Or it might just be easier to get a fork bottom of of Howdy.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Feb 2006
    Wapakoneta,Ohio
    17
    Just finsihed taking it for a shakedown run handles just like before the wreck
    will still be a few weeks before I can ride wrist didn't handle the clutch to well
    1985 Honda ATC200X
    1986 Honda TRX250
    1973 Mustang coupe
    1991 P71 Corwn Vic
