Hepl 250r shifter sticks
I just bought an atc 250r and the guy I bought it from put a new case on it and now the shifter sticks when you pick it up or push it down. Is this normal. Will it break in or is there a problem? thanks for the help...
Probably put the return spring back where it belongs when he reasembled it. The return spring for the shifter shaft is on the clutch side of the motor if i do remember correctly. Make sure you have a service and owners manual nearby to reference though!
is that something I would have to tear the whole thing appart to do?
//ArrowChat Integreation Code
