Results 1 to 3 of 3
Thread: 250sx help !!!- Moved to Trikesylvania
    Hobesound, FL
    8
    I am trying to get off my swingarm on my 250sx and i cant seem to find out how to do it
    Do i need an alin key or do i need to take the nut thingy off frist and how do i do that ???
    PLz post, Thank you
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    This is a simple process, you need a big allen key or you can use the end of a chizel that you can put a wrench over. When you get that big nut out you have to unhook to differencial on the other side then the swing arm drops right down: Make sure you when you put the swing arm back on that that bolt is adjusted right because if not it wont go all the way in and your swing arm will become loose
    WWW.FASTRACKZ.COM!! Totally dedicated to Atv's/MX/Sleds. Go take a look at the photoalbum and drop into the forum and say hello!
    crd00's Avatar
    Feb 2006
    323
    Pm me if you have any more trouble
