Results 1 to 8 of 8
Thread: Front Shock Covers?
    Mar 2003
    44
    Front Shock Covers?
    Hey everone i was wondering how easy is it to replace the two black shock covers? i dunno exactly what they are called the one on my right fork is ripped. How much do these usually cost?
    Thanks
    1985 Honda 250 SX
    1983 Honda 200X
    1983 Honda 185S
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    mine
    my 200x has no forkboots.....i dont think it harms it that much....i personally think some trikes look better without them!
    Feb 2003
    California
    623
    They are called fork boots. I was wandering myself as my 200x needs them. I think they go for around $20-$25.
    Minnesota
    784
    you need to unclamp the forks and undo the brake, either from the handle bar, or the line from the caliper or master cyclinder, but then you'll have to bleed them. slide the new boots on, slide forks back into clamps, tighten bolts, hook brakes back up.
    I've seen some atc's with shock boots from 4x4 truck shocks on them, they stay very flexible in cold weather, and come in many colors. I've always wanted to put clear boots on one of my trikes.
    als250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    J.D.- Fork boots run between $15 & $25 depending on size and length, in cat. from www.denniskirk.com. If their for the sx in your sig., 1st- block the rear tires (I use tire chocks) and put floor jack under eng. skidplate. Next you'll need to disconnect the frt. brake cable (at adjusting nut and where cable clamp hooks to slider , then take headlight ass. off.(just need to take "rubber bands" loose from forks I believe) Next loosen bolts on upper and lower triple. Jack frt. up and slide hole frt. end out of triples. Put fork boots on forks and reverse procedure. Shouldn't take but an hour or so! Hope this helps!
    Al
    p.s. I personally don't think sx is one of those that looks good w/o them!
    TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
    '86 350x (latest addition)
    '85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
    '85 250sx(supertrap exhaust,chrome rims)
    '87 200x(restored)-'85 200x-'84 200x
    Mar 2003
    44
    yes it is for the sx. Thanks fo all of the info everyone. I wasnt to sure on the technical name for them :-D
    1985 Honda 250 SX
    1983 Honda 200X
    1983 Honda 185S
    May 2002
    Cortland, NY
    1,195
    Running a fork without the boots that was made to run them will ruin the seals quicker. I like the look of fork boots personaly, my tri z didn't come with any but after I rebuilt the forks I went with some red ones and it looks much better.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
    Mar 2003
    32
    I just bought a pair off of ebay from someone in TN. Paid $23 for them. They seem to be higher quality than the ones I've seen at the stores. This guy makes them himself do a seach for 200X on ebay and you should find them. I think they do add value for keeping dirt out of the fors. Going to put mine on next week.
